Hi, I'm new to the forum, I am from Argentina, and I just came to work one 3-axis cnc milling siemens 808d controller ...
Although I never work with cnc machines, (just making drawings and solidworks autodidact nx) .... siemenes Estududiando the driver I meet some problems not solved ...
I've seen lots sold siemens 840, and 828 or 802, but there is little information about the 808d which is what I have ... When postprocesar probe with several, but I do not mind which is the most similar to mio ...
What is the most similar to my control? sabra someone tell me exactly?
Customize with postbuilder 840 d, after having a thousand problems I realized that the 840 was the least likely, apparently the 802 is more similar...
Someone had found similar problems? thank you very much
