585,994 active members*
4,834 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > NEWBIE NEED HELP HOW TO CONFIG 5 AXIS HEAD HEAD B/C MACH 3
    Nov 2004
    70
    HI ALL NEED HELP ON CONFIG 5 AXIS HEAD/ HEAD B AND C
    DO I HAVE TO WRITE A SCRIPT FOR THE B/C
    DISTANCE CENTER FOR TILT AND ROTATION .
    OR INPUT SOMEWHERE IN MACH 3 THANX
    Re: NEWBIE NEED HELP HOW TO CONFIG 5 AXIS HEAD HEAD B/C MACH 3
    Your g-code needs to account for this.
    Nov 2004
    70
    im new at this, do i have to input any parameter for tilt and rotate compensated offset
    when the head cut tilt drill on the angle and cut simultaneous.
    so everything do in the cam and post compensate that
    Mach3 can NOT compensate for 5 axis offsets. The g-code needs to tell it exactly where it needs to go. So it's up to your CAM and or post processor.
    Jun 2006
    48
    Or LinuxCNC could save you, using 5 axis kinematics module for compensation by controller in "real time"...
  1. Series 1 Boss 3 Head Rebuild (2J Head) - Stuck Here.
    By 1875 in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2022, 07:59 PM
  2. I need of getting my head around converting a milling machine NEWBIE
    By wavewizards in forum Uncategorised MetalWorking Machines
    Last Post: 04-24-2013, 07:55 PM
  3. newbie in over his head!
    By h50n in forum CNC Tooling
    Last Post: 02-26-2012, 03:20 AM
  4. IH Head ways head lose issue
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 03-15-2011, 06:06 PM
  5. The SHIZ, a newbie in over his head thread.
    By Crusty1007 in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2010, 06:54 AM
