Bob,
Thank you for an honest and fair review. We can’t apologize enough for the rough setup, but consider that your feedback is appreciated to improve our product and that we take customer experiences very seriously.
We would like to elaborate on some of the points that have been brought up in this thread. Hopefully this will answer questions for some and ease concerns of others.
1: We are not just distributors of our CNC mills. The electronics are designed and built individually in-house in the United States, the mechanicals and mounting systems are designed, machined, and installed here (with some parts imported and others made in America) but the basic cast-iron frame is imported. The frames were originally designed to the specifications of Industrial Hobbies, but that was before we were involved.
2: Our in-house test setup and test procedures are substantial, but we are always looking to improve them. We add to the checklist every time a fault is discovered so that we don't have a recurrence. While the gear heads are part of the imported frames, we carefully drain, flush, and inspect each one, refill them with new oil, run thermal tests on the gear drive, replace the spindle bearings with a higher quality set, and ensure that continuous operation for several hours yields no issues. Based on the problems Mr. Lalonde has experienced, future tests of the limit switch systems will include their homing functionality as well. We're not yet certain what more we can do to decrease the problem of connections loosened in shipping; we already ferrule all the internal wiring by hand and check each connection before it leaves the shop, but we will review further options and are happy for advice. The next version of our CNC (which will be available in August) has far fewer connections and should be less susceptible to such issues.
3: We will definitely adjust our marketing material to indicate that achieving full travel requires overextension, and will adjust our factory Mach3 settings to take into account Mr. Lalonde's suggestions.
4: One other customer has experienced similar computer problems in the past. At the time, faulty boards were suspected and replacements shipped under warranty, but overheating now looks more likely. It doesn't get as hot in Connecticut as out west, so we never experienced these issues during testing. Our newer CNC design has replaced the mobile computer console enclosure with an integrated PC and screen on an armature, so similar problems should no longer be present. We will nevertheless work up a test for this before new-model mills are shipped.
5: Our base cast iron frames undergo third-party quality testing (from a European based inspection firm) before we accept them from the foundry, and we are very strict (we once rejected an entire order rather than ship product we didn't feel was good enough). Bolt hole patterns are not a defined criterion, though, so variation occurs. We're not certain whom Bob spoke with who is displeased with our communication on the matter, because we thought everyone who has asked about bolt hole patterns has been apprised that we can only supply them after we take delivery. If we were slow in responding to a request for information, though, then we certainly do apologize.
6: We have spoken with several foundries in an attempt to have our frames cast in America, but the cost is prohibitive for our machine. We're always looking for new foundries to qualify, though, and as we supply larger machines we look forward to the point where we can have everything cast here without pricing ourselves out of the market.
As changes are made, we will continue to update this thread or redirect everyone to a dedicated thread.
Thank you for all of the suggestions and support,
Charter Oak Automation
