510,021 active members
3,687 visitors online
IndustryArena Forum > Hobby Projects > Jet Engines and Ram Jets > 1.st stage axial compressor designed with DIY automated CAD construction workflow
Results 1 to 2 of 2
    Registered
    Jul 2007
    177
    Hello Guys - here is my first attempt on an axial compressor for jet enginge purposes. to go easier with the free form surface design I wrote an automatism in Cad Scripting under Rhino VBR
    Rhino Script _ Fan Blade Geometry Generator - YouTube
    Why reach for speed, when you could have precision instead!!!
    Registered
    Feb 2006
    98
    Re: 1.st stage axial compressor designed with DIY automated CAD construction workflow
    have you estimated the stage compression ratio? At such a small scale the blade airfoil matters less due to the Reynolds number. what is the compression ratio that you are shooting for when you have the stages done?
    Ray,
    Life is a choice, death is choice poorly made.
  1. CNC Workflow Example
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 03-28-2014, 05:32 AM
  2. I need some suggestions on workflow.
    By Profoxcg in forum Aspire
    Last Post: 01-20-2014, 04:22 AM
  3. Edgecam Workflow
    By meegers in forum EdgeCam
    Last Post: 05-17-2013, 12:40 PM
  4. Looking for easy workflow 2.5D CAD
    By adx in forum Uncategorised CAD Discussion
    Last Post: 05-21-2012, 05:08 PM
  5. Sketchup 7 Pro to CNC workflow
    By ktz in forum Uncategorised CAD Discussion
    Last Post: 05-19-2011, 10:12 PM
