585,925 active members*
3,411 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alphacam sloping help
Results 1 to 6 of 6
    May 2014
    45
    Hello all,
    New to this forum, 6 months on smc record 220 router with alphacam. We are a mom and pop mill shop specializing in running trim / doors /stairs. This router is used primarily for curved casings with profiles, making templates for our knife grinder, and various cutting and dado functions. I have the profiling for curved casings figured out, Have the cutting and pocketing figured out. What is the sloping function for and what does it do? I can't seem to make any rhyme or reason out of it. Will it help me with tapered door sills? or should I stick to making them with profile function?
    Thanks Ben.
    May 2011
    108
    Re: Alphacam sloping help
    The sloping is nice, if you have a fixed slope, you need to cut with a Ballend
    May 2014
    45
    Camnerd,
    Thanks for reply... What plane does sloping refer to. I am not sure how to apply it, and to which toolpaths.
    Kind regards, Ben
    May 2011
    108
    if you attach a Alcham File, or a Picture to show the Job - then I can give you some advice...
    Dec 2008
    10
    The sloping is like running a bevel cutter around the panel. Very useful for one off parts when you don't want to pay out for a special tool bit.
    Create exactly the same as vertical but add the angle value and optional round over top and bottom to create a bevel without a bevel tool.
    Steve Searle, Alphacam Training Manager Alphacam 2014 R2
    Vero Global Support Portal http://customers.verosoftware.com/
    Mar 2015
    I have the same problem whit Alphacam 2014 r2 and xilog plus working to Morbidelli Author 427 .
    how i can fix the problem ??
    I tried to mirror the work and then generate the n , as some have suggested , with the post processors but the problem remains and the tool path is reversed and does not work well.
    sorry for my english!! I'm Italian....
  1. ALPHACAM
    By bugattiman in forum Alphacam
    Last Post: 10-17-2020, 11:34 AM
  2. ALPHACAM HELP
    By spindlefish in forum Complaints and Praise Discussions
    Last Post: 10-24-2013, 10:37 AM
  3. Sloping table on 3040t
    By Glenncou in forum Chinese Machines
    Last Post: 09-30-2013, 03:23 PM
  4. AlphaCAM 00 and AlphaCAM V5 - same postprocessor
    By Ziyan in forum CNC Machining Centers
    Last Post: 10-10-2011, 12:59 AM
  5. Alphacam
    By Loffie Botes in forum Community Club House
    Last Post: 07-14-2011, 09:53 AM
