585,992 active members*
5,225 visitors online*
Results 1 to 3 of 3
    Jan 2014
    Postprocesor/solidcam/sinumerik
    Solidcam postprocesor for sinumerik 810d or emco 450 concept turn.
    Can someone please help.
    I finded postprocesor for sinumerik 810d, but works only in milling.
    In turning it says- no machine. please help.
    Feb 2013
    49
    what machine do you want to use? milling machines use milling postprocessor, lathes use lathe postprocessor, general rule u can't use a post that is not written for that kind of machine. u might be able to use postprocessor written for other milling machine to your milling machine as long as ur machine will be able to understand the gcode generated. the error you get is because the post you have is for milling and not for lathe.
    Feb 2011
    252
    Re: Postprocesor/solidcam/sinumerik
    I have for SOLIDCAM.
    [email protected]
  1. Need iTnc530 and Sinumerik 840mill postprocesor
    By turbosnek in forum Post Processor Files
    Last Post: 05-27-2014, 07:44 PM
  2. Dijalog 4 postprocesor for Solidcam
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-20-2013, 06:39 PM
  3. Replies: 0
    Last Post: 11-02-2013, 03:13 PM
