584,862 active members*
5,363 visitors online*
Results 1 to 3 of 3
    Dec 2013
    4
    Angry Disappointed in Muscle Chuck
    I purchased the Muscle Chuck in February and have had recurring problems especially with the use of the 1/4 inch collet. Today marks the 4th time I have had a down cut tool screw itself into a piece of wood. I have checked tool diameters and made sure that the collet is inserted correctly, but the problem returns. I am not making aggressive cuts or using high feeds and plunge rates. This has happened in medium and soft woods. One of the instances was with a 1/16 inch up cut tool making a 1/16 inch deep pass.
    I am putting the chuck and the collets in my tool box and going back to changing out the collets on the router. I can't afford the time or the material.
    Dec 2013
    4
    Re: Disappointed in Muscle Chuck
    As a follow up I received a call from John DeRosa who makes the Muscle Chuck and and I am returning the parts for evaluation. Something is amiss in the diameters of the collets. John promised that the issue would be handled with new parts as required or a complete refund if I wish.
    Mar 2015
    I also use the muscle chuck, I have had great results total TIR .0004 made my own collet press fit style. Have never had a cutter pull out. many time use a .500 dia 4" long no sweet. 10000 rpm 150 ipm feed
  1. Looking for good CAM software,disappointed with Esprit Cam
    By javed08 in forum Uncategorised CAM Discussion
    Last Post: 02-28-2015, 06:44 PM
  2. 4th axis, is this normal or should I be disappointed...
    By lance-ftw in forum Uncategorised CAM Discussion
    Last Post: 06-10-2013, 09:45 AM
  3. disappointed with Sherline and needing recommendation
    By brian257 in forum Benchtop Machines
    Last Post: 03-18-2012, 07:05 PM
  4. Zebra Muscle Coalescer
    By TravisR100 in forum Haas Mills
    Last Post: 10-24-2009, 01:56 PM
  5. Muscle Powered DIY Router
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 05-02-2006, 03:13 PM
