Hello fellow cnc pros...I have a Fadal 4020 with a CNC88 control, (1996 model), and the control/machine is stuck in optional stop. We checked the switch and it is ok, traced the wires to the plug at the circuit board and there are no loose or broken wires. As I understand from reading the Fadal manual, the optional stop switch is not even supposed to affect the machine UNLESS the M01 code is present in the program. My cnc buddy has used this machine a number of times since he bought it, and said he always used the machine in optional stop mode (with the switch in optional stop ON position). He never tried it any other way because all his programs were simple and quick. Now that I am using the machine for longer runs and/or multiple tool changes, I have discovered that this was probably a problem when he bought the machine. As I said, the optional stop is not supposed to work UNLESS the program has the M01 code present. We can still use the machine, it is just a pain if you want to do something else while the machine is running but instead you have to be at the machine to press START to continue after each tool change. Any ideas, anyone? Thank you...hope to hear from someone soon.
