Does anyone have the lubrication specs for a Cincinnati 5VC-750? In particular, I need the spindle oil and hydraulic oil specs is available. Is there a manual that has these listed that I might buy? How much?
Thanks in advance for your help!
The Cincinnati 5VC uses a P38 oil for the spindle and main hyd fluid. Only use brand name oil like Mobil DTE light that only has rust and oxidation inhibitor. Do not use an oil with anti-ware additives.
Mike cncmachineservices (dot) com
Thanks Mike, I appreciate the help!
Dave
Dave,
You also need to change the Hyd. filter
