A problem. The machine movement disorder, and sometimes pause?
Is usually caused by electrostatic interference of control card, laser cutting machine advice customers on the chassis and laser power shell reliable earthed;This problem is more complex, there are two reasons, first is static electricity may be affected, especially in internal control card to the machine, so the customer will be in the chassis shell with the chassis of the laser power supply is connected to reliable ground wiring. The second is to be pulled out in time with computer cables, lest appear interference,the prospect of laser cutters for sale is very good.
B. Cutting material cutting does not reach the designated position, cutting continuously, accuracy is not high?
This basically has the following several reasons, first is the laser tube use time is too long lead to power decreases, then this may be lenses consumables work for too long time lead to wear and tear, these are all need to change the position. If it is a light spot is not straight, deviating from the exposure in the location of the sheet metal, it need to manual control laser tube and laser cohesion, to ensure that can light from can accurate output. Generally the workbench of the impact with the stability of the ground is uneven, the error in the following two or three MM, it's mainly according to the material aspects to judge. The individual will also be synchronous wheel of screw loosening or above the belt loose, the tool is needed for adjustment in place.
C, there was a noise machine movement?
Noise in a word, we must stop authority power to inspect at that time, the most main or on synchronous wheel bearing ball, is it because work too long and cause damage, need to change this time. In addition to check the motor shaft, this also need to be replaced, you can consider, sometimes is cutting material fall within the cutting machine, stuck key location. If heard a noise inside the laser power supply, the joint may be poor contact, looking for qualification, welding, can be normal use,the prospect of laser cutting machine for sale is very good.
D, laser cutting machine does not emit light?
First checks professional water cooling system, CNC laser cutting machine is water cold box office problems, if water are described.the problems, first of all, let the water under normal circulation, sub water protection be used again. Then you can see signs of the ammeter, generally have signs of swing, did test into electrical signs, if signs nor the light into electricity, so disorders in general is power, also want to change at this moment. If the program can be walked, but still not out of the light, then check the machine card, this also want to use electric meter under test, is it card signal problems.
E. The machine does not walk bits or processing with computer graphics do not conform to the and irregular?
Boot view, have access to electricity, with servo motor drive on electricity, ordinary people use hand push is certainly push motionless, driver can work properly, the lamp is green light, electricity, can also promote takes motor and motor shaft may be broken, must be replaced,the prospect of laser cutter machine for sale is very good.
Attachment 237298
