Hi everyone... I've built my own cnc router at work, off hours. To save on the cost of a kit I've made my own. It's relatively a good size for me anyway. The travel on it is X 34in Y 24in Z 9in. I've bought 2005 ball screws 5mm pitch(.197in pitch). I've bought 3 axis kit on ebay from act motors dm860 drivers, nema34 860oz.in 8 leads step motor and 3x 60volts power supply. Now the problem is I can't have feeds over 50ipm. My driver are set at 6400 micro steps per turn if I got this right. I've tried to lower the steps to go faster but it stall, jerk miss steps ect. The wiring is parallel I think, red& blue to A+ yellow& black A- white& brown B+ and orange& green to B- so far this wiring gets the most torque I think. The problem is it's the first time I do a project like this and I'm not sure of anything. Do I need bigger 1600oz.in step motors, higher power supply or better drivers, not sure. Maybe my ballscrew pitch is to low 5mm maybe 20mm pitch would be better. Don't now if its something in mach3 I'm using a gx620 dell 3.4ghz small factor form pc with xp pro. Please help would like at least get 100ipm for rapide.
Thanks for support, please help:drowning:
