Can someone who has V26 and support ,so you have the latest update, verify a lathe bug.
Tried the latest demo and found a bug in the tool compensation when posting from Cutting Arc Center under current settings.
Tool path is offset from the part correctly when Compensation and Collision detection is on. Tool path reverts to Theoretical point programming when the Compensation is on and Collision detection is off. I believe the demo was latest version because the Theoretical point bug in tool creation had been fixed.
If someone can verify this and turn it in, maybe it will be fixed by V27.
