Re: About Encoders...
Number 1, the hall effect sensors, or the now more common, hall tracks on an encoder, is used to commutate a BLDC motor.
With Galil you do not need any feedback to the drive, apart from hall inputs, the encoder itself is returned to Galil to close the loop, preferably set the drive to torque mode.
The controller, or trajectory planner, Galil, is much preferable.
Mach uses the drive closed loop, which is inferior to the Galil approach.
I have used Galil for many years now, and it is the closest thing to an Industrial CNC controller.
Al.
Albert E.
