585,555 active members*
3,111 visitors online*
Results 1 to 14 of 14
    Sep 2004
    235
    Stepper motor is stalling
    Hi
    Yesterday I had a strange problem with my x axis that`s powered by a
    1200 ozin motor. The first time I used it I had no problems then the
    second time that day the x axis seemed to be stalling. I had not
    changed any of the Mach3 settings and I manually turned the ballscrew
    to see if the axis was binding... no problems with binding were
    detected. Today I started up the machine and had the same problem but
    I lowered the acceleration and velocity and now it works. But sometimes
    the motor still stalls.Does anyone have a idea as to what caused this
    sporadic problem.
    Regards Barry
    Dec 2004
    1316
    If you relocated any of your motor, or spindle wires it could be causing a problem with with induced signals, tripping your limit switches, if you have any.
    Jason
    Jan 2006
    121
    Stalling
    Have you tried swapping your X and Y drives to see if the problem follows the drive or stays with the motor? It could be somethink like a bridge rectifier only delivering half the power. This would only be valid if each drive is fed AC instead of DC. This is only a guess as you didn't give a lot of details
    Jon
    Sep 2004
    235
    Stepper stall
    Hi
    I didn`t have much to mention to clarify the problem with the stepper because this machine has been up and running for 6 months. I have not made any changes to any electronic components or the software ...Mach3. Up until now I didn`t have any problems with any one of the three motors. I had thought about swapping the X and Y drives to help eliminate some of the troubleshooting variables. That will be my next move.
    Regards Barry
    Sep 2004
    235
    Stepper stalling ...still problems
    Hi
    I thought I had this problem solved by switching the x axis
    driver for a spare Gecko I had. The machine worked for two
    weeks now I have the stalling problem again. I had this machine
    working fine for months. I can`t seem to get a handle on the
    problem. I`d appreciate some troubleshooting tips.
    Regards Barry
    Did you call Gecko? Sounds like the drive was bad? Possibly overheating due to hot weather?
    Jul 2006
    21
    Mi impression is that Gecko drives require external current sensor resistor. I wonder if it goes open under heat. Since you replaced the driver with new one the resistor got relocated too. Quite often mechanical stress can make the resistor problem dissapear for a while. But it comes back later. Replace the resistor.
    Also could you monitor the power supply current (not the voltage) and see if there is any difference between normal operation and stalling. If current goes higher when stalling it points to the motor problem. If current goes lower it points to the controller or wiring between controller and a motor.
    Set the jumper for "NEMA-42" if your motor has 800 in-oz or higher holding torque.
    Mariss
    Mar 2007
    12
    I've just touble shooted a similar problem. X axis didn't stall but moved extremely slow while measuring twice the amperage of the Y axis. Switch the cabling to eliminate the board and pointed to a bad Xaxis motor. Switched motors and it is the motor.
    Question: System is using MDrive 34 (MDMF3424) steppers with IMS encoder and I have been quoted high dollars for a full replacement from the CNC manufacturer. Can I easily verify that it is the motor and can the stepper be replaced and matched to the original encoder?
    Jan 2006
    121
    Checking Motor
    If you know what the phase resistance is supposed to be, you should be able to ohm it out and compare.
    Jon
    Mar 2007
    12
    Jon,
    I don't find any reference to the phase resistance and no help from th manufacture. Can I compare the reading from the good drive? Where would I measure from?
    Danr
    Jan 2006
    121
    Checking Motor
    How many leads does your motor have? What colors are the wires? What are the labels on the drive where they are connected?
    Jon
    Nov 2011
    I got a question.
    why my cnc router when is cutting the motor is ramdon stop moving, especially in arc , curve sometimes lines too, i thing this is a stalling?
    MY SET UP
    nema 34 motor
    microstepping current set peak 5.7 amp rms = 4.0 amp
    micros stepping set 1600 = 1/8
    lead screw is 10 tpi
    motor tunning
    step per velocity inch or mm p min acceleration inch or mm/sec
    16000 40 10
    by the way i got one power supply for each stepper motor
    power supply information
    ( 3 POWER SUPPLIES ) =
    48V 7.5A 360W DC Regulated Switching Power Supply
    I HOPE YOU CAN HELP ME THANKS
    DO YOU KNOW IT THE COMPUTER PARALLEL PORT HAS TO BE 3.3 VOLT OR 5.0 VOLT BEACUSE MINE HAS 3.3 VOLT OUT
    1695
    If it's stalling only when cutting curves, try turning off the backlash compensation to see if it helps. If it does, one of your accelerations settings might be too high.
