Attachment 239596
Step one: laser tube installation
1.the laser tube installed in the back of the machine, turn the laser tube protective cover, you can see two semi-circular laser tube bracket. First two stents to open the mouth of the laser tube light (negative terminal) # mirror direction toward a carefully placed two U-shaped bracket
2.laser tube bearing on the magic belt connected, the laser tube fixed
Caution When installing:
1 glass laser tube are fragile, moving the laser tube in the mobilization process, please be careful!
2 laser tube from the mouth and No. 1 mirrors should be within 2 cm.
3, to keep the inlet port (the optical port side) located beneath the body tube.
4, two U-shaped bracket supports a quarter and three-quarters in the laser tube.
Step Two: Waterway Assembly:
The picture shows the front and rear map chiller, red mark points expressed as: 0: plus outlet, 1: Switch 2: Temperature DRO, 3: Alarm Red, 4: Working green, 5: Main power into electricity, 6: water conservation side, 7: intake, 8: outlet, 9: outfall, 10: cooling holes, and then the next picture shows the right side of the cabinet door open and intuitive diagram after, respectively, shown in red, 1: cold water three core small aircraft machine power plug, 2 :: pump power four core small aircraft plug, 3: water chiller small aircraft to protect two core plug, 4: Tap water inlet adapter, 5: Tap outlet adapter, 6 : pump switch interface, 7 trunking.
Assembly steps of:
1, will be carried into the bottom of the cutting chiller cabinet, place the same direction chiller and cabinet.
2, using a 1 m long silicone tube 6 * 9 7 connection diagram faucet spout 1 and 4 of Figure 2, using silica gel in Figure 1 meter long pipe connection 6 * 9 8 1 and 2 faucets the faucets on the 5th (silicon tube to fully enter the faucets)
3, the negative terminal of the faucets use 2.5 m long silicone tube connections 6 * 9 4 Tap 2 (Side by side) and the laser tube using a length of 1.2 m silicone tube connected to Figure 2 of 5 Tap (side by side) and tap the positive terminal of the laser tube.
Note: Each pipe fittings butt firmly to prevent leakage; hose to straighten can not be discounted in order to avoid poor water pipes over the line to pass through the hole of the cabinet.
The third step: the installation of the pump
1, the pump unit into the bottom of the cabinet (and chillers as)
2, 4 * 6 endotracheal length of 1 m, and the outlet port of the pump 3 connects the two ends
3, 4 * 6 using tracheal length of 2.5 meters and the 3 end 2 (Side by side), then tighten the outlet hole through the cabinet and the Y-axis towline, the towline and then through the X-axis cutting head inlet port.
Note: trachea can not be discounted, trachea butt to tighten to prevent leakage.
Step Four: Fan Installation
1, the fan should be placed behind the cutting machine.
2, using the outer diameter of the exhaust pipe 150MM, length of 1.5 m, the ventilation hole cutter suction port and connect the fan and fastened with wire 1MM good.
3, with the other exhaust pipe OD 150MM one end connected to the hole cutter, toward the other end of the outdoor 1MM wire fastening with a good length of the exhaust pipe depends on the distance between the outdoor machine fixed.
Step Five: The control panel installation
1 installed in the ship sailed away on the opening position, should pay attention to the O-sign forward.
2 Touch the switch installed in the holes on, and tighten with a flathead screwdriver.
Four M3 screws 3 controller panel into the panel hole and tighten the M3 nut, fixed control panel,the prospect of laser marking machine for sale is very good.
