585,970 active members*
4,384 visitors online*
Results 1 to 18 of 18
    Jun 2014
    4
    Exclamation Firmware Overwritten
    Hi guys,
    This is my first post, i'm desesperated with a Multicam 1000 series M CNC router.
    I´ve overwritten original firmware with trash (by error) and now cnc router doesn't work.
    I don't have original 3 firmware files and i've looked for it with no luch. Maybe someone could release it?
    I think 3 files may be something like J2_xxx.bin, h4std.uc & h4ldr.uc
    Thanks in advance!
    Jun 2010
    463
    Re: Firmware Overwritten
    how old is your machine
    Jun 2014
    4
    It's dated july 2006.
    What i'n not really sure it's if board is J or K series. How can i know it?
    Jan 2008
    35
    are you without support (to, just like me right after the bill was settled :-((( )
    anyway, long time ago, had lost of fun since with my MG204 ~2000
    I ran into the same problem like you're havin' now when installing new firmware
    the proces / program(motionmechanic) leave's lot's of room for mistakes
    pretty sure my files will be to old for you, you can have them anyway, I don't need them any more :-)
    I run it another controller, although the old one still works if you now where to kick . . .
    let me/us now how you're getting on please
    good luck
    Jun 2014
    4
    You're right kessfrees , the lack of support is very bad and always money ahead.
    I appreciate sincerely if you can send me the files, I 'm not really sure it will be compatible but i have nothing to loose, now the controller is as usable as a rock.
    With motionmechanich the only thing you can do is save NRAM with parameters of the machine (but not extract the firmware completely, i think) and send a firmware that you own (that three files in the same order) to flash.
    That NRAM file is stored as .uc and contains something like this:
    Version Information
    **** MultiCam Inc. ****
    ** Router Machine S/N 1-101-R05240 **
    Loader V6.70
    Standard V6.70
    MCIF V4.41a
    uCITO V2.06c
    Keypad KDM20 V1.22
    Controller :
    LC520 Rev 2 Interface M64 (ID 22)
    Serial Num #2806
    Speed 133MHz
    Memory 8M
    Step Delay ON
    IP Address 192.168.1.79(255.255.240.0)
    Bus Voltage 36.924 VDC
    Module Information
    MODULE INI_STD 2 6.70
    MODULE INI_MD4 20 1.28
    MODULE INI_INIT -3 6.70
    MODULE INI_INVERTER 5 2.19
    FIRMWARE 4.41a
    SERIAL_NUM 2806
    FEATURES 212797
    MEMORY 3
    MPU_MHZ 133
    CONTROLLER_REV 2
    CONTROLLER LC520
    Machine Parameters
    -145.787430 1 set_float
    145.787384 2 set_float
    [more memory positions]
    Maybe the next option will be get another controller/driver, but first i'm gonna try all possible options.
    Jan 2008
    35
    I've sent you a PM
    Jan 2008
    35
    I've got your PM
    can't sent email now, server is down
    i'll keep trying
    Jun 2010
    463
    OK....I need to know what version of software that you have.
    Exit jobserver
    Find motion mechanic
    if you have a gray screen, goto Tools and goto Terminal
    at the >
    Goto File and capture NVRAM
    cut and paste what you see on the site, I think I might actually have the fimrware file.
    Jun 2014
    4
    The text i paste is copied directly from motionmechanic.
    I think it might be useful.
    Loader V6.70
    Standard V6.70
    MCIF V4.41a
    uCITO V2.06c
    Keypad KDM20 V1.22
    Controller :
    Serial Num #2806
    Speed 133MHz
    Memory 8M
    Step Delay ON
    Module Information
    FIRMWARE 4.41a
    SERIAL_NUM 2806
    FEATURES 212797
    MEMORY 3
    MPU_MHZ 133
    CONTROLLER_REV 2
    CONTROLLER LC520
    Jun 2010
    463
    I actually have this file, if you would send me your email address. I can send it to you
    Dec 2012
    8
    Hello, are you fix it problem?
    I have same problem on Multicam 1000 series M CNC router.
    Firmware Overwritten.
    I lost firmware on old hard bracked disk.
    And i lost DBI file for correctly connect, i can't use Mechanical Service Tool
    And now I am looking for the same files. Anybody can me help? Pls
    Jan 2008
    35
    Have you seen this thread ?
    https://www.cnczone.com/forums/multi...d-looking.html
    My machine is still running very fine !
    Many thanks to MCP again :-)
    Dec 2012
    8
    Quote Originally Posted by keesfrees View Post
    Oh thank you, i try later. but do you have DBI file? Because Service Tools request this file for correct connection
    Attachment 470788
    Attachment 470790
    Jan 2008
    35
    Quote Originally Posted by Tixanden View Post
    This doesn't work unfortunately.
    I don't know about a DBI file, there is one mention of it on his forum though :
    https://www.cnczone.com/forums/comme...ml#post1172937
    But I doubt if this will be any help to you.
    If I my suggest, retrieve and post your'e machine specifications here, following these instructions :
    https://www.cnczone.com/forums/multi...ml#post1657662
    And for someone like MCP.
    Dec 2012
    8
    I make capture NVRAM with "MCP" instruction. And i have
    ****Router Machine S/N M2400****
    Loader V6.70
    Standard V6.70
    MCIF V4.41a
    uCITO V2.06c
    Keypad KDM20 V1.20
    Controller :
    Serial Num #2400
    Speed 133MHz
    Memory 8M
    Step Delay ON
    IP Address 192.168.0.88(255.255.240.0)
    Bus Voltage 36.178 VDC
    Module Information
    MODULE INI_SELFTEST 1 0.00
    FIRMWARE 4.41a
    SERIAL_NUM 2400
    FEATURES 199485
    MEMORY 3
    MPU_MHZ 133
    CONTROLLER_REV 2
    CONTROLLER LC520
    Also, I can not open the "Firmware Update" program.
    Since it requires you to specify the "DBI_file.mdb" in the connection settings
    Dec 2012
    8
    Quote Originally Posted by MCPservice View Post
    I have same model of Multicam can you help me?)
    I can't send PM to you. "User's mail is full"
    Dec 2012
    8
    Ok, i found my original machine parameters. But when i "store" i was not choose to "parameters". I not looked where it will be stored. I overwritte INIT user file in NVRAM. And now i need sample of "init file.uc. Anybody can sent self file? i will look what be need coded coded in this file.
    Dec 2012
    8
    I found the original parameters file.
    And I received the "User Init" file from the Multicam service center in Russia
    The machine is repaired, everything works!
  1. pluto firmware
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 11-11-2014, 12:54 PM
  2. Firmware question
    By scrambled in forum CNC Machine Related Electronics
    Last Post: 06-08-2011, 12:35 AM
  3. PDX15 Firmware
    By Jäger in forum Stepper Motors / Drives
    Last Post: 05-12-2011, 01:58 AM
  4. Firmware upgrade 2.5
    By routerman in forum Viper Servo drives
    Last Post: 12-25-2008, 06:47 AM
