585,768 active members*
4,172 visitors online*
    Jun 2014
    Cant Set Depth of Chain
    I am attempting to import a DXF of two circles to Lazycam. When importing my DXF to Lazycam, the chain only shows a depth for a single point on that chain.
    I have tried with multiple different files. How is it that i can get the depth for the entire circle to appear? I have attached a picture of what i am seeing. It is and isometric view of two concentric circles.
    Any help would be greatly appreciated.
    Jul 2003
    92
    Re: Cant Set Depth of Chain
    It would help if you could post a sample DXF file so I could try it.
    But in the meantime consider going into Setup/Loading Options and checking the value you have in "Connection Line Tol. used in Optimize." I suppose there is a chance your value is set so small that LazyCam isn't seeing your entire circle but only segments of a circle?
    If that doesn't help post a file and I'll try it and see if I can help.
  1. Cutting Simple chain Mount with my Homemade roller chain cnc
    By ninja0731 in forum DIY CNC Router Table Machines
    Last Post: 05-23-2014, 06:34 PM
  2. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  3. cut chain?
    By winaa in forum BobCad-Cam
    Last Post: 07-10-2011, 03:56 AM
  4. E Chain
    By Bobbyr70 in forum Linear and Rotary Motion
    Last Post: 01-21-2008, 01:09 AM
