Attachment 240514
Laser marking machine parts warranty period for each different, which is very important, so I suggest we buy the equipment must be careful, and you say in general manufacturers warranty period refers to the machine's warranty, But compare button door manufacturers also say that all parts of the warranty period, it is not true, the whole factory warranty is the warranty service, and many parts of the warranty period is more than a year. Beyond here propose a laser laser coders parts warranty reference to everyone, hoping to purchase equipment before you have some help,the laser marking machine price is reasonable.
1, the warranty period galvanometer, import is generally one year, but are in the country to maintain its maintenance, the price is very low, domestic galvanometer warranty is 2 or 3 years, maintenance costs and import the same.
2, warranty laser modules are for the year, general domestic use, its life is about three years or so, due to the replacement of the second can be used to replace the old one, can be part of a cheap .
3, CO2 glass tube, which is a kind of pipe manufacturers to distinguish between a general warranty for the normal use is three months and a maximum of not more than six months. The real life is also up to about 1 year. But the price is very cheap.
4, CO2 RF laser tube, the warranty period is 1 year, the current maintenance of the inlet tube inflated, RF power board can be in the country, the price is relatively affordable. Generally its service life can reach more than five years, made generally not more than 5 years.
5, field lens, beam expander, optical lenses, generally do not have the warranty period, you can and if you do not use the manufacturer's instructions can retire or change, provided that you do not engage in particular took a look like a lens. Use of all a long time, mainly to protect you on it, as well as some of the lenses on the attention of the CO2 laser energy changes or changes in the optical path of the system will lead damage the lens.
6, laser marking cards and software, which is generally said to say a product warranty is one year, but you can and you let the other 3-year warranty, why, because its maintenance cost is almost zero. Normal life is more than five years.
7, IPC or PC, this one is 3 years, something the computer industry, I believe you know more than I do.
8, the cold water of the warranty, usually one year, are generally designated suppliers for the factory warranty for you, you'd better have vendor contact information. Warranty period, the cost is not very high. Normal life is more than five years.
9, the control system, which is the manufacturer warranty service warranty to you, but these are very simple stuff, so look electrician will understand, of course, some are microprocessor controlled a little bit complicated. You can talk about and manufacturers, is this part of the provision of technical support, warranty period can be extended to indefinite.
10, Q switch, the warranty period is one year of normal use, the life in general can be used to more than five years, made that have not yet defined. This thing and laser lens look, pay attention to the protection enough.
11, marking the rack cabinet, this part is no warranty, Lantie bunch, you protect, and improve health enough. Machines for a long time, you see much more, you can change about the color, you can change what does not matter,the prospect of laser marking machine for sale is very good.
