As the subject suggests, I have a MCD-500 and the chip conveyor quit running. If anyone has any idea what to check next or further diagnose the problem I would appreciate it.
This is what I have checked and found so far:
1) There is no power at conveyor motor, and no power out at board (240v 3ph) when conveyor is turned on at the control
2) Inspection of the motor junction box looks normal, capacitor is not burned
3) Conveyor is not jammed
4) Chip conveyor breaker is on, and power is flowing through it
5) Verified that the chip conveyor is still enabled in the control
6) Diagnostics shows it turns off and on, changes between 0 and 1
7) Board check light turns on (red) when chip forward is pressed
8) When reverse is pressed reverse solenoid works and board reverse check light comes on (red)
I am afraid it may need a new board, but would like to be sure before ordering one.
