Super Definition Plasma Cutting Machine Played a Role in Kjellberg Contour Cut
How Super Definition Plasma Cutting Machine Played a Role in Application Area of Kjellberg Contour Cut?
Super definition plasma cutting machine is described as better than high definition plasma cutting in the column of New Announcement at CNCzone.com.
A registered member of CNCzone is curious about super definition plasma cutting machine and its advantages over Hypertherm True Hole Technology. As Jimcolt asked details of super definition plasma cutting machine, i.e. dimensions, hole tapers, consumable life and edge metallurgy data, I’d like to fully demonstrate how this world first super definition plasma cutting machine played a role in application area of Kjellberg Contour Cut.
Super definition plasma cutting machine has been largely applied in saw blade processing, construction machinery and farm machinery, where are the main application areas of Kjellberg Contour Cut. Just like Kjellber Contour Cut, super definition plasma cutting machine is also capable of cutting holes with a diameter to thickness ratio of 1:1 for cutting thickness 3mm to 25mm, and with the kerf angle bore ≤1°, the upper limited kerf verticality of Hypertherm True Hole Technology.
With these capabilities, we can confirm super definition plasma cutting machine is better than high definition plasma cutting, playing an important role in the application of Kjellberg Contour Cut or Hypertherm True Hole Technology.
The SteelTailor post in New Announcement at CNCzone.com about super definition plasma cutting machine and high definition plasma cutting machine:
http://www.cnczone.com/forums/news-a...ades-high.html
SteelTailor--The world leader of portable CNC cutting machine
www.steeltailor.com
