Econo V rails come in sizes ready to mount to any standard extrusion, 80/20 - 20, 40 series or other system equivalent. They can also be used on a fixture of your design if you incorporate fixturing points or slots in your own designs.
They come standard with
- Zinc anti-corrosion plating
- Pre-Drilled Holes for direct mounting to extrusion slot
They are designed to fit with any size #1, or 2 (or 3/16" or 3/8") roller v wheel, but will work with any other such groove roller that you are able to find including delrin wheels. Manufactured here in North America from quality grade steel. Rails can be butted up end to end if cut squarely.
Get yours here
