AJAN BKM CNC SERIES has been designed for satisfying the requirements of the user’s to be able to cut pipes and sheet metal with CNC plasma cutting system.
Attachment 241306
First of all, the most important differences from the similar machines are that the conventional plasma cutting generator hasn't been used and it has been equipped with Precision Plasma series 130 Ampere or 260 Ampere precise cutting plasma generator, torch and the required gas selections can be made automatically. For that reason, it can cut steel, chrome and aluminium pipes with high accuracy.
Model wise Specification:
Machine Model BKM 6300 BKM 6600 BKM 12300 BKM 129600 BKM 6300-600 BKM 12300-600 Pipe Legth (X Axis) 6000 6000 12000 12000 6000 12000 Pipe Minimum Diameter Ø 50mm Ø 300mm Ø 50mm Ø 300mm Ø 50mm Ø 50mm Pipe Maximum Diameter Ø 300mm Ø 600mm Ø 300mm Ø 600mm Ø 600mm Ø 600mm
Visit us now! for more details and best cnc cutting machine.
You can also download catalog for more details.
Attachment 241314
