I believe my VF0's memory got corrupted a few weeks ago. I had a few garbage characters popping up on the screen. I initially thought it was something with my keyboard and/or keyboard/video PCB.
I could clear the chars and reseting was working fine so it was more a nuisance than anything else... or so I thought.
Last week it got to the point where the machine would boot and just lock up. Sometimes I'd get a keyboard beep by pressing reset or any other key, most of the times I wouldn't.... but I could never get into any other screen but the main page.
Spoke with HAAS and my local HFO. They're immediate response was to replace the main processor board. I had read a few post regarding software reinstalls due to corrupted memory,etc.. Many were able to reload and things corrected themselves. The machine would only boot into the maintenance screen once every 20-30 resets...
Figuring I had nothing to lose and new board/reload looming, I was able to finally clear the BBU/RAM (did not clear the flash). Discovered after doing so this got the machine back booting consistently. Went to load my parameters though and discovered my parameter file is junk.
If my processor is bad, I'll find someway to eat this and do the full repair but I'd really like to exhaust all efforts to prove it IS bad as it's some serious money to dump into a 16 year old machine. It's puzzling to me now as all the proper status lights are on (processor and MOCOM & I/O PCBs), the machine is booting up every time now and I was able to use an old VF2 parm file that I adjusted as much as I could for my machine - with the correct steps, ratio, calculations as I understood them...etc.
Thoughts were to have my HFO come and simply reload my parameters. My closest HFO is 6 hrs round trip away though. It's at the point now the alarms are gone and I'm able to jog the X and Y Axis. The VF2 parms I had are not for the vector drive so I have the Z axis disabled right now but it's far enough I have no alarms and the voltage/diag screens look good.
I'm just hoping someone can share their 98 parms to get me a little closer to what I had. I've since been through the voltage checks and reset all the connectors. I'm in the fortunate situation this machine isn't a production dependency for me and plans are not to attempt any machining until the HFO does come out (I know losing the shuttle settings and such I'll need their expertise to make the fine adjustments). I just want to get a better comfort level she's going to run ok and/or more definite signs of bad board before I continue. If I can get closer and just watch the machine for a week or so to see if the processor starts acting up, it would make me feel better in my decision on what to have them do. Trying to avoid having them come out, spend the labor to reload parms on a potentially bad board .... it would then be my luck as they driving away it would start back acting up.
Thank you for any help or suggestions.
**** Several have provided older models and I have things close, just would like to actually see some from this vintage area ... 97/98/99 ... something around there. I'm willing to compensate for your time I just really want to cross out anything I can do here before the call back to HFO.
Thx
Mike
