586,009 active members*
4,744 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Angle plate calibration
Results 1 to 2 of 2
    Nov 2012
    162
    I just received a new angle plate and want to check its accuracy. There was no sheet included and it looks cheap. I don't have another angle plate but do have a fairly well set up shop.
    List of tools available (please include all suggestions as I might have missed a tool or two).
    Surface plate 2 X 2ft and 6in X 6 in
    Height gages
    dial indicators galore
    precision squares
    rotary table
    sine bars and related equipment
    surface grinder
    mill
    lathe
    etc. etc.
    Any ideas?
    Thanks in advance.
    Yoda
    Sep 2008
    117
    Re: Angle plate calibration
    If you understand the concept illustrated here you will be able to calibrate your angle plate.
    Gene
  1. Adjustable angle plate for milling
    By jeffrey001 in forum Canadian Club House
    Last Post: 03-27-2013, 07:09 AM
  2. A Axis Mach3 Angle Calibration
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 09-19-2010, 01:58 AM
  3. Any tips for designing a fixture plate / tooling plate?
    By thackman in forum Benchtop Machines
    Last Post: 12-19-2008, 06:26 PM
  4. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 06:48 AM
  5. tables for bar, plate, angle stock?
    By davesaudio in forum Mechanical Calculations/Engineering Design
    Last Post: 11-05-2006, 03:34 AM
