585,727 active members*
4,241 visitors online*
IndustryArena Forum > CAM Software > Esprit > help with simulation models
    Jul 2014
    Howdy...
    Running Esprit 2013 for millturn on an new Okuma LB3000. Purchased the post for this machine that included an accurate model of the machine for the simulation. My problem is the turret is bare and I'd like to add the 3D models of the Sandvik Capto tools we've purchased to the turret model so it can be a more accurate representation. I can't figure out how to do this. I am a fairly new user with no formal training.
    Any help would be much appreciated.
    Mar 2014
    44
    Hi Rico. This is not possible with standard Esprit, but if you use addin Pimpel Toolshapes, this is no problem. You can load and stack al capto tools. Where do you live?
    Eigen draaibeitel in ESPRIT met Pimpel ToolShapes - YouTube
    Jul 2014
    Re: help with simulation models
    There is an add-in from esprit that will allow you to add solid tool models. I cant seem to find it on their web site, but it is called Station Solid Simulation Add-In.
    Oct 2007
    47
    Arjand is wrong. You can add turret models for live holders or lathe tools. You need the STL model from Sandvik. then orient it correctly (along "X" on the machine). Then open the file with the LB machine. Add a solid on the turret, browse to the location, etc, and associate it to the turret station you want - tip, you can use the same solid on multiple locations if you have 2 or more of the same holder. You only need one STL. Save the file (be sure to set "embed solid into file")
    Mar 2014
    44
    Quote Originally Posted by surfsup View Post
    You understand that you respond to an old topic? Maybe there are standard possibilities., there is just an easier way
  1. Need CAD simulation models for WorkNC for Haas/OKK
    By BlueBlazer in forum Uncategorised CAM Discussion
    Last Post: 05-02-2021, 05:19 PM
  2. Edgecam Simulation Models, Shrink Wrap for Solidworks?
    By Matt Cardente in forum EdgeCam
    Last Post: 06-13-2013, 01:22 AM
  3. Looking for simulation machine models
    By montie in forum GibbsCAM
    Last Post: 01-07-2013, 08:41 PM
  4. Looking for 2D models to cut . . .
    By Tazin in forum Uncategorised CAD Discussion
    Last Post: 08-19-2011, 05:23 PM
  5. How to edit simulation machine models?
    By Dan B in forum Esprit
    Last Post: 05-21-2011, 08:23 PM
