Hi
How Wiring the SSR SOLID STATE RELAY to the HY-JK02-M5 break out board
thanks
Hi
thanks
I only know how to wiring the solid state relay to realize motor control with single chip. For reference only
220VAC to wire the main contact of solid state relay;
Live wire L and R to wire the normally open and closed contact separately;
null line to wire the null line.
For reference only
Machine, For save Labors.
--From Jason(Wisebuy)
one way is to use the relay on the breakout board to control your solid state relay
if your not using all 5 axis outputs you can try using either a step or direction output to control the solid state relay
posts 1018 and 1020 have some info on the breakout board :-
http://www.cnczone.com/forums/open-s...e-easy-85.html
John
