585,951 active members*
4,332 visitors online*
    Jul 2014
    Stepper Motor Kit
    I've recently purchased a stepper motor kit from automation technologies and comes with two 23 nema stepper motor, two KL-4030, a breakout board, 40V and 5V power supply. Is it possible to just run the motor without using the breakout board but just only with the power supply, driver, and motor itself? Also, can any micro-controller software be compatible with the driver?
    Jan 2010
    2141
    Re: Stepper Motor Kit
    Quote Originally Posted by omegasniper View Post
    If your signal source can drive the optoisolated inputs of the KL-4030 directly, then you won't need a breakout board.
    According to the manual at http://www.kelinginc.net/KL-4030.pdf each signal source will need to be capable of handling current in the range of approximately 7 to 16 mA.
    As far as microcontroller software, do a search for GRBL.
  1. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  2. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  5. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
