586,000 active members*
4,902 visitors online*
Thread: Extra comma
Results 1 to 13 of 13
    Extra comma
    i have a techno servo post processor and it show an extra comma after each values of x , y and z
    N130 Z15 .
    N140 G02 x15.346 . y18.369 . R18 .
    May 2012
    180
    Re: Extra comma
    Ok, and what do you want done about ?
    Re: Extra comma
    the cnc does not accept a comma in this position
    i can provide you with my post processor(i already posted in ''share post processor " version x5 )
    can we remove this commas
    May 2012
    180
    Re: Extra comma
    Yes of course, I'll have a look for you.
    Re: Extra comma
    i have already delete the comma after each values of x y and z
    but it still one more probleme
    the first comma after z-6 . f190.9 (N140)
    N140 G1 Z-6 . F190.9
    N150 Y110.851 F381.8
    N160 G3 X-314.22 Y100.851 R10.
    N170 G1 X-10.128
    this is my post processor
    thanks
    May 2012
    180
    Re: Extra comma
    Is it the same as one you posted in share.
    I've tried to duplicate the problem using your post, control and machine.
    But can't get the commas.
    If you make a zip 2 go and send that over?
    Re: Extra comma
    i hope this will help
    May 2012
    180
    Re: Extra comma
    Lovely, I will have a look this evening.
    May 2012
    180
    Re: Extra comma
    Could you send me a program as a file. Cheers
    Re: Extra comma
    ok
    i thinks i have detect the source of the probleme in fact it is not an extra comma but the way of writing number
    every time z change we have the probleme
    as you can see in N360 G1 Z-1. F95.5 , N920 G1 Z-2. F95.5 and N 1480 G1 Z-3. F95.5 we have an extra comma but in N80 G1 Z-.5 F95.5 we supposed to have an extra one but we it is not and we have an absence zero
    but for the rest we have no probleme at all
    N640 G1 Z-1.5 F95.5
    N1200 G1 Z-2.5 F95.5
    you can see also in ligne N260 G3 X2.923 Y5. R2.501 and N570 G3 X38.407 Y5. R2.5 the y valuer has an extra comma also in ligne N380 G3 X38.407 Y12.195 R5. we have an extra one after R value witch is in the end that way i thought it is just a simple point in the end but it is not she is just an comma after 5
    so in short if we have 0.5 we just have .5 the cnc does not accept it cause it could be any number
    if we have 1 we just have 1. as well as the first
    if we have 1.5 we just have 1.5 accepted
    thanks
    Attached Files Attached Files
    May 2012
    180
    Re: Extra comma
    This should now fix your issue.
    Cheers
    .PST file on my google drive.
    https://drive.google.com/file/d/0B2E...it?usp=sharing
    Quote Originally Posted by azerty View Post
    ok
    N640 G1 Z-1.5 F95.5
    thanks
    Re: Extra comma
    yes that work perfectly
    thanks a lot
    May 2012
    180
    Re: Extra comma
    No problem.
  1. Replies: 3
    Last Post: 10-13-2012, 12:16 PM
  2. using extra tools.
    By TAdams_R&D in forum Fanuc
    Last Post: 01-16-2012, 10:25 PM
  3. extra grounding?
    By cuttinloose in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-05-2012, 02:37 AM
  4. EXTRA MACHINES DON'T NEED
    By 1Adam12 in forum Community Club House
    Last Post: 04-02-2009, 02:38 AM
