I am using the 3 axis Homing... Z does not Jog, Input is bit 22?
I have my X axis and my Y axis Jogging and Hitting the limit switch,... and then they back out 1000 counts... which on my test mill... is .100".
My Z axis should do the same... and the input limit for the Z is the same... it is wired to input 22. I can push the switch and it goes high, then when release low.
__________________________________________________ _______
As well, the Z axis will disable and not run, if the limits are enabled. So I turned them off... in my INIT file... I would like them to work...
Thanks, I need a clue as to what to look for...
Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
