585,761 active members*
3,975 visitors online*
IndustryArena Forum > CAM Software > Esprit > feed adjustment
    Hello everybody,
    Is there a possibility to emit different feeds in a contour with ESPRIT 2011?
    Preferably without having to undertake a massive PP adjustment.
    The issue is that the milling machine (diameter 35mm) runs perfectly on the straight surfaces. However the machine struggles with the corner radius (3mm). The material is 4305.
    Hope somebody can help me out.
    Thank you in advance
    Regards
    AJV 32
    May 2007
    115
    Yes, just insert is over technology!
    Many thanks for your answer.
    But could you please explain that to me a bit more detailed?
