585,727 active members*
4,008 visitors online*
IndustryArena Forum > CAM Software > Hypermill > better graphic display of milling tools or as a wireframe
    Jul 2005
    8
    Hello
    Can anybody tell me if it’s possible to increase the accuracy in the graphic display of milling tools? For example the ball mill as a net or something similar....(Hypermill V2011 with SolidWorks),
    I know that Work NC offers it and you can see very nicely what the tool or rather the milling path is doing in particular positions.
    I experienced the inaccurate graphic display of the tool (especially when you zoom in) as unsatisfactory.
    Has anybody got a idea?
    Regards
    liphan
    Hello
    Your tessellation- what value has it?
    Regards
    CAM Alex
    Jul 2005
    8
    Hello Alex,
    I don’t know to find the tessellation setting?
    Regards
    Hello
    If you want to adjust the tessellation, then you have to select the surfaces that you want to see clearer, afterwards right click-options/settings-element settings- tessellation parameter and here you move the slider to finer.
    I hope I helped you out!
    Regards
    CAM Alex
