585,937 active members*
3,999 visitors online*
    Jul 2014
    26
    MAZAK MULTIPLEX 410, Mazatrol T32-4, MFD-ERROR
    Hello,
    I bought a lathe Mazak Multiplex 410 with control Mazatrol T32-4. The lathe has about two weeks in the hall for the duration of the repair tool heads, a dozen times was strapped to power and run for a while (5-10 minutes) and everything was fine until yesterday. Lathe launched once (system loaded from a floppy disk) shifted a tool heads and then turned off, an hour later she gave advice to run it.
    When loading data from a floppy disk system for about 55% percent of throws error "MFD ERROR". My guess is that this may be a problem with the system diskette or floppy, but hard for me to be more determined because this is my first Mazak. Perhaps the problem is also with some battery if it was an efficient system to run instantly from the cache rather than from a floppy disk, it took me much longer (green bar went from 100% to 0% about 2-3 minutes) several times can system is loaded immediately.
    If anyone has any experience in this topic, I asked for any help.
    LINK TO FILM WITH ERROR
    Regards, David K.
    Jan 2011
    Re: MAZAK MULTIPLEX 410, Mazatrol T32-4, MFD-ERROR
    That is a "main floppy drive" error. Call the MAZAK service center in Atlanta, Ga. and ask for the tech dept. Talk to Tim Kirby, and he will point you in the right direction as to the availability and price on a new drive. You may want to get on ebay and try to find the error code book for your machine. Hope this helped, and good luck!! KZ
  1. Mazak Mazatrol M64groupa error??
    By KE5KBG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-18-2023, 12:34 AM
  2. Mazak QuickSlant 20 with Mazatrol T4 -ERROR 1: SERVO LAG EXCESS X1 AXIS
    By Acustical in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-24-2012, 03:44 PM
  3. grnding is a Mazak Multiplex 620
    By rulo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-27-2011, 01:38 AM
  4. Mazak Multiplex 6200
    By Rich S in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-07-2008, 10:09 PM
  5. Mazak - Mazatrol M32B - 42parameter error
    By rajappa in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-05-2007, 06:17 AM
