585,749 active members*
3,622 visitors online*
    Jul 2014
    Mazatrol T32B - Serial Communication Parameters
    I've got a variety of old Mazak controls that I've networked with some DNC software.
    I've had little to no issues with the T1, TPlus, and T2 controllers, as I had information regarding the serial parameters available to me and was able to ensure the ports were set up correctly.
    Unfortunately, no such documentation seems to exist for our T32B Controller.
    Does anybody have any documentation concerning which parameters set the baud rate, parity, etc for the serial port and which values set what values? Searches haven't turned up anything of value thus far, although if I have missed something, feel free to scold me and send me in that direction. Sometimes Google can be an art, not a science.
    Thanks in advance.
    Dec 2007
    300
    Re: Mazatrol T32B - Serial Communication Parameters
    The CMT baud rate is a User parameter on the Mazak control. It is parameter I1<DV1>.
    Here is a CMT baud rate table for the I1<DV1> parameter:
    Setting Baud Rate
    0 19200
    1 9600
    2 4800
    3 2400
    4 1200
    5 600
    6 300
    7 110
    Other CMT Parameters
    Another parameter to look for when communication is not working between the PC and the control is:
    I65 (bit input) -- 00000010 (actual parameter setting on the control).
    This parameter controls the Assignment of ports for CMT
    We are concerned with the last 2 digits of this parameter. There are only 2 settings allowed:
    00000010 (channel 1 setting) or
    00000001.(channel 2 setting)
  1. Mazatrol CAM-M2 communication parameters
    By eltorio in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2020, 10:01 AM
  2. Serial communication
    By Limpan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-25-2011, 05:17 PM
  3. Fubared T32B Mazatrol
    By compuslave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-05-2011, 10:49 PM
  4. MAzatrol T32B Control
    By davidblair in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-26-2010, 05:28 PM
  5. Mazatrol T1 communication parameters?
    By sinjin341 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-22-2008, 09:35 PM
