585,974 active members*
4,219 visitors online*
Thread: HSC milling
    Hello forum
    Is it possible to change the diameter of the circular motion by HSC milling?
    I’d like to mill a nut b20 with a 16HM cutter.
    Greetings
    Jun 2008
    39
    Hello hmoc,
    It was changed on July first and has to be in the internet as an update from this day forward.
    The thing now works so that the “overlap” arranges the diameter of the circle (positive value=% from cutter diameter / negative=radius in mm) and the “directional overlap” arranges the improvement for each circular motion (+/- as above)
    It always makes 90% from path to path.
    Greetings
    Yardman
