585,996 active members*
4,005 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Start and end point output during line editing
Results 1 to 7 of 7
    Nov 2007
    91
    Hello
    When I create line editing with compensation, start and end points are always triple-digit (N15 and N26)
    N14 T2 M6 S265 F56 (SCHRUPPFRAESER D=30 / R=15)
    N15 M13
    N16 G93 X401 Y0 Z0
    N17 G7 C5=-90 B5=0 A5=-90 L1=1 (270 GRAD)
    N18 (ABSATZ 6 SCHRUPPEN LINKS OBEN)
    N19 G0 X308 Y-55.201 Z50 <---- ?????
    N20 G0 Z2
    N21 G1 Z-5.8
    N22 G43 X308 Y-35.2
    N23 G41
    N24 G1 X-18
    N25 G40
    N26 G1 Y-50.201 <----- ?????
    N27 G0 Z50 M9
    N28 G74 Z-230 L1
    N29 G7
    N30 G93 X0 Y0 Z0
    is it possible to change this output?
    Banditman
    Jun 2002
    825
    Hello Banditman,
    I believe it’s possible to change something:
    There must be a raw
    zero_value = 0.0010, 0.0000
    in your *.MAC file.
    Delete (my) there and try again
    You certainly have an old PP…
    Thorsten
    Grüßle<br />nebbe
    Nov 2007
    91
    Hello Thorsten!
    That’s great! Thanks a lot!
    Now I have one more problem: when I remill a part with profil – job and several coverings, the PP gives one coordinate more than it should (N21)
    Is it also possible to prevent this output?
    N14 T10 M6 S170 F60 (WASTI-SCHRUPP D=63 / R31.5 )
    N15 M13 T1
    N16 G93 X0 Y0 Z0
    N17 G7 C5=0 B5=0 A5=-90 L1=1 (180 GRAD)
    N18 (UEBERFRAESEN POS.50 LINKS)
    N19 G0 X342 Y-445 Z50
    N20 G0 Z12.6
    N21 G1 Y-410 <--- this coordinate
    N22 G1 Y-125
    N23 G0 Z20
    N24 G0 Y-445
    N25 G0 Z10.2
    N26 G1 Y-125
    N27 G0 Z20
    N28 G0 Y-445
    N29 G0 Z10
    N30 G1 Y-125
    N31 G0 Z50
    N32 G74 Z-230 L1
    N33 G7
    N34 G93 X0 Y0 Z0
    Banditman
    Jun 2002
    825
    It’s with moving with o degree, right? Or tangential moving.
    Actually it has to be out. Which version do you have?
    t.
    Grüßle<br />nebbe
    Nov 2007
    91
    “It’s with moving with o degree, right? Or tangential moving.” – YES
    Version : Inventorcam 2007 R11 SP 2.1
    Jun 2002
    825
    That was “correct” in the version 8 and it’s inside of version 12 again!
    I have SolidWorks with SolidCAM
    t.
    Grüßle<br />nebbe
    Jun 2002
    825
    Little correction:
    It already works in SC R11.2 SP4
    t.
    Grüßle<br />nebbe
