585,766 active members*
4,068 visitors online*
Results 1 to 3 of 3
    When I want to print a document with "DOCU" "PRINT”, then a white window usually opens. Is there a way that a certain frame opens instantly, without having to load a frame over "Load"?
    Hi-Jan Friedel
    The days of us using this type of document have long gone, but if I remember correctly you can rename a frame into std.frm and then this will be loaded by default.
    Thanks for the tip that’s how it works!!!!
