584,860 active members*
5,239 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > electrode documentation under 64Bit
    Sep 2006
    32
    Hello
    We change our operating system to Win7 64 Bit and since that the XML documentation doesn’t work anymore.
    According to the Tebis installation manual, we also installed the newest 65bit Java version.
    Has anybody solve that problem yet?
    Thank you in advance
    Hello
    I just was about to report the same problem. However in my case the problem seems to be related to the new 3.5 R3. We tried out everything and then we found out, that the elec_card and elec_list was not copied into the XML-file folder in the new version so therefore when opening the style_sheet, it cannot be found.
    Is that the same in your case???
    Well I still work with XP and when I generate the electrode documentation with the R2 then it works now.
    You should try it out.
    Greetings
    Youngbone
