585,717 active members*
3,924 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > calculate weight for volume via Tebis?
    Hello
    Is it possible to calculate the work piece weight out of the volume of the piece in Tebis?!
    As the piece weight often varies, It would help the logistic department if one needs a 12,5 tons lorry or maybe something smaller =)
    Regards
    Hello Tillerium
    When you have a closed topology then it works.
    The function element-info shows you’re the volume.
    In the function Calc the volume is shows and a formula is inquired where you simply have to multiply the volume with the density to get the weight..
    Kind regards
