585,567 active members*
3,470 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Sharpening drill bits by hand
View Poll Results: Do you sharpen drill bits by hand on a bench or pedistal grinder?
Voters
856. You may not vote on this poll
  • Yes I do it all the time!
    608 71.03%
  • No, they never cut right!
    46 5.37%
  • Sorry, I don't know how to do that!
    63 7.36%
  • Its better to throw them away!
    30 3.50%
  • No, we have a drill sharpening machine!
    94 10.98%
  • What's a drill bit?
    15 1.75%
Page 1 of 14 12311
Results 1 to 20 of 266
    Question Sharpening drill bits by hand
    What's a drill bit?
    Mar 2005
    1136
    do it all the time, or at least did until i made my drill sharpening jig. Hand sharpening of twist drills seems to be one of points of delineation between those who really know what they are doing and and those that don't. It shouldn't be that way though, its just not that tough to do. It does take some skill vs just plain old knowledge, but that will come quickly with some practice and everyone should learn how, its a basic shop skill. with a drill point gauge, nicely dressed wheel and a spare 3/8 bit, long before you grind your way through that bit you'll have the hang of it!
    Jul 2005
    12177
    Quote Originally Posted by Mcgyver
    ....... its just not that tough to do. It does take some skill vs just plain old knowledge, but that will come quickly with some practice and everyone should learn how, its a basic shop skill. with a drill point gauge, nicely dressed wheel and a spare 3/8 bit, long before you grind your way through that bit you'll have the hang of it!
    Mr Mcgyver I could not disagree more!!!! I have demonstrated the procedure to, and tutored in drill sharpening techniques, many, many people. There exists a percentage which I put at around 20% that just never get the knack. It is like any other acquired skill, some people pick it up almost naturally, some will get there over a variable time period with persistence and practice and some will never get there.
    Mar 2006
    1625
    At today labor rate and the fact that you can never really grind a drill point with both flutes cutting at the same time unless you use a comparator. The cost to grind a drill in other than a home shop or to be used in a manual machine is not worth it for a 3/8 drill. As a note I did tool grinding for 10 years and can split point. But unless there is no new drill a regrind will only be use if it the last option.If your a job shop I can see why you would, but a manufactor would not was the time Boston shop rate $95h/60m=$1.58/min x 5min(regrind time)=$7.50 what the cost of new?Buy a dozen at a time and send out for regring when you have many to do The shop we send to charges $2.50/drill under 1/2 and that is with a split point
    Mar 2004
    1804
    When I was young my Dad (machinist all his life) tried to teach his dumb arsed son how to do it. However, I could just never quite get the hang of it. Well many years have passed (along with my Dad) and a friend (Mentor) got me to doing it in 15 min!
    Being out in the country, I can't just run down to the nearest supply house especially on a Sat. or Sun. when I break the cotton picken drill. So this skill is handy to have for those times as well as when you need a different point for some specific material to drill a couple of holes and finish the project. No matter how many drill you try to keep as backup, there are times you NEED to have the skill!
    Art
    AKA Country Bubba (Older Than Dirt)
    Mar 2006
    1625
    If there one area that we as a trade have lost it is the manual tool grinding of both mill and lathe with most shop going to insert tooling the young guys just don't have the opportunety to do this much and it's a skill as Bubba said we need at times
    Mar 2005
    1136
    Quote Originally Posted by Geof
    forget 20%, did you know half the people out there are of below average intelligenc?
    Geof, or shall i call you Colonel Pickering, A sad portion of that 20% maybe people who just don't have the capacity to learn, and a still sadder portion might not want to learn, but i maintain that most of us, if we puzzle out the shape of a well ground bit, the motion we'd have to give it across the wheel to obtain that shape and a way of measuring (and understanding why) the lip length and angle, could be taught. next thing you know we'll have wager going 'the rain in spain......"
    Lakeside i see your point for production, but for commercial jobbing, maintenance, toolroom or home (as you point out) it's neccessity - a skill that would be beneficial to acquire, most probably have it except for many of the home shop guys. I mostly use the T&C grinder now because drills sharpeded with it are so accurate, but thats a luxury few have and and mostly drilling isn't a precision op (oops there's another pandoras box) .
    i sharpen large drill by hand , i ve seen lots of guys who can sharpen a drill then blow it when the try to split point it , i can t tell you how many times i ve picked up a drill and someone has ground across the cutting edge leaving a negative rake at the most critical spot on the drill , which is at the point , i don t know how these things cut sometimes
    Mar 2006
    1625
    Quote Originally Posted by dertsap
    shear & horse power
    Jul 2005
    12177
    ...Geof, or shall i call you Colonel Pickering, ....... but i maintain that most of us,....... could be taught.
    I have been called a lot worse than 'Colonel Pickering' so I will not quibble.
    Regarding your other point in your first post you said "everyone should learn how" with which I disagreed; (does my grammar come up to a Higgins' standard?) now you "maintain that most of us......could be taught".
    I will respectfully point out that 100% - 20% = 80% and I think most of us will agree that 80% is most of us. Which is probably the first time Pickering and Higgins agree .
    Mar 2005
    1136
    ahhhh but my dear Colonel Pickering, everyone should and most could, the two are not incompatible. its splitting the point that we are having difficulty with
    in my opinion and experience that there is only a small percentage of machinists who do things properly in the shop ,be it stupidity or laziness ,
    this is what makes us professionals , not everyone can do it ,
    Most bench or pedistal grinders do not have wheels with keen sharp corners, the kind needed to do a nice split point! Also the position of the drill on the wheel of a pedistal or bench grinder is very awkward for seeing what you are doing! So for those shops which have a basic surface grinder available for such tasks, the results are usually better and easily done not to mention they usually have a light within reach!
    I was fortunate to have had a good teacher in highschool metal shop, he had me sharpening everything!
    Eric
    Jan 2006
    4396
    Arrow Drill Point Sharpening
    As Lakeside, Geof, Widgit, Dertsap, and others pointed out that drill point sharpening is a must. Personally I think I was doing it wrong for many years. Either poor equipment, being rushed all the time and not taught right from the get go. Geof a few weeks ago sent me a PM on how he was taught drill sharpening and it's tops. So many people do things so many different ways that as luck would have it I was born in the era. I tried Geof's method and low and behold it took less time (when I finally got it right) not to mention very accurate. For me that is difficult because when I was young I had an accident which left three digits on the Left Hand in pretty bad shape. Usually a little duct tape can keep it from shaking too much. All I ever want is to be a good Machinist. Thanks for the Tip Geof. :cheers:
    BTW: Geof could you PM me on split point drills ?
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jun 2005
    866
    I have no problem sharpening my bits by hand, and do it when necessary. They seem to cut, pretty well. I know they are not perfect, and I am not willing to invest the time to make them perfect. But I can revive a dull bit alright. When you need a bit, you need it now.
    May 2006
    1469
    My dad, who was what we call a "fitter and turner" had me sharpening drills as a young kid.
    To me it's a bit like riding a bike, you don't lose it.
    He would say "it's a feel thing".
    He would say the same when I was using a drill press or tapping a thread.
    Taught me to sharpen lathe tools and cut threads.
    Now I know my skills won't "cut it" in a modern production machine shop, but around the farm or in the
    shed fixing things I am very glad my dad took the time to teach me these things
    Jan 2006
    4396
    Nice Videos
    Thanks Eric,
    The Videos are excellent. Drill Doctor looks like an economic choice. I've always seen them in Enco but didn't think they were any good. Plus a lot of people say they aren't any good. This goes on the wish list
    The other drill grinder looks a bit pricey but that in the shop would be a great investment.
    Toby D.
    Schwarzwald
    As for those who voted to just throw them dull drills away, they should sell them on eBay, its a perfect place for dull homeless drills!
    On second thought, send them to me!
    Eric
    Jun 2006
    478
    I don't do it any more, we have a drill/tool grinding dept. but I think every "real" machinist should konw how
Page 1 of 14 12311
  1. Sharpening Small Bits
    By ToyMaker in forum Toolgrinding / Toolgrinding Machines
    Last Post: 01-09-2017, 08:02 PM
  2. Hand Sharpening End Mills- Can You Do It?
    By ImanCarrot in forum MetalWork Discussion
    Last Post: 06-04-2010, 07:08 PM
  3. Sharpening Engraving Bits
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 12-04-2009, 04:47 AM
  4. drill sharpening books
    By nc9933 in forum MetalWork Discussion
    Last Post: 09-14-2009, 11:50 AM
  5. Sharpening Iscar Cam Drill Heads
    By Shotout in forum CNC Tooling
    Last Post: 03-05-2009, 05:27 AM
