Hello
I’ve got an old Mikron that can be set horizontally. One just has to take another axis instead of z during programming. I can output another axis in the output of PP right now. Is it possible to make this another way? I mean before PP?
Hello
Hi
It depends on your PP.
What controller does your Mikron have?
Probably old TNC155?
You probably may do it with KEB. When you adjust a unit, “top” has to show to the z-axis of the machine. Choose/create an appropriate/new KEB (for example “ahead”) and then call this during machining (pivot levels).
Greetings
