585,662 active members*
3,206 visitors online*
    Nov 2011
    14
    Hello I have a short question,
    When transmitting data, I always encounter the following problem:
    With the data transfer to the PC, all programs arrive as they should.
    However, when I want to move the program back to the machine, then the machine doesn’t receive anything.
    Machine is a FP3 Dialog 4 Contur 3.
    Kind regards
    Lars
    Oct 2006
    7
    Hello
    The problem could be linked with the cable. I believe it has to be a null modem?!
    Regards
    Ruppert
    Nov 2011
    14
    The cable can’t really be the problem because we have often used it before on the Deckel.
    Just nobody can remember how it worked ^^
    Hi
    I have the same machine, go to BA 11 and delete all existing programs, then BA14 or 15 (I work with it every day but when you try to write it do it’s something completely different), green arrow key for PO1, then the green arrow key again possibly relates to the tool lengths, then on the computer, send, on the top left you should see how the record number run along...
    If nothing arrives, then usually its due to a write error and the Baud rate is misaligned: then there is a wrong sign at the beginning of the program or something like that...
    It depends on the transfer program....
    Kind regards
