585,589 active members*
2,840 visitors online*
    Hello
    I need some help urgently!!! I switched off the machine yesterday ( turned off controller, not main switch) and this morning the screen displayed X axis error V.
    Well I found out that the glass scale is dirty.
    What really bad is that the machine was then switched off over the main switch and now it doesn’t start anymore.. The screen stays dark.
    Please help me quickly.
    Thank you!
    Aug 2006
    14
    Hello
    Can you switch on the machine and proceed?
    If yes, then you screen is defect..
    If not, then select BA16, if you get 30BA16 underneath the screen then you need to re-initialize the machine.
    First press CLEAR (red) and quit (green button)
    Machine gets initialized
    Please wait 30sec
    After select BA5. Now check if the machine starts....
    But so you now: the programs will all be gone!
    Good luck!
    Cor from Holland
