502,912 active members
7,107 visitors online
Results 1 to 3 of 3
    I have a problem with changing tools in a DMC 50V from -96 with a Grundig Dialog 112 controll
    The machine has been used in production but only with one mill and therefore not using the tool changer for over ten years, last week we had a service engineer from DMG Scandinavia here for a check on the machine, and when he tried to change tool the machine "locked" itself.
    There is in the manual a procedure how to run the machine free from the tool changer if there is a malfunction, but I got no response or movement with this procedure.
    Do anyone perhaps have any idea on how to solve this problem?
    I got hold of a former employee of Deckel i Sweden he had a service manual with "the code" for the service menu in the Grundig control
    The code
    [QUOTE=Axegone;1513733]I got hold of a former employee of Deckel i Sweden he had a service manual with "the code" for the service menu in the Grundig control[/QUOT
    Did he tell you thw code and how entry ?????
    I have the same problem.
    Thanks in advance
    Daniel
