Hello
I have a sinnumerik program that has to be translated into Fanuc 18iTB.
Could anyone give me a tip?
The machine is Emco Maxturn 65 with Fanuc
Regards
Hello
Regards
Why don’t you do it manually with an editor? With copy and replace or manually.
A little example for Hori milling machine 4-axis:
Fanuc
O0100
N5( machine: )
N10( controller: FANUC )
N15G10G90L20P1X0168.500Y189.250Z169.600B0.000
N20G10G90L20P7X-126.900Y189.250Z168.6B0.000
N45M01
N50
N55T30
N60T30M98P9140( T30 MK DM63)
N65T31
N70H1D2
N75M56
N80G54.1G90P1G0M11B0.0M10
N85X-320Y-30S1000F850M3
N90G43H1Z150
etc.
N95Z-1.5
N100G1X-130
N105G0Z50
N110X-320Y30
N115Z-1.5
N120G1X-130
N125G0Z50
N130X-320Y-30
N135Z-3.5
N140G1X-130
etc..
N550G0G30G91X0Y0Z0M9
N555T31M98P9140( T31 MK DM18)
Subprogram call is M98P. A subprogram has to be 4-digit. So you can take P1234 or P0001 for a slot hole subprogram.
If you want to repeat P1234 20 times, just write P1234 L20 or P201234.
If you have a subprogram with macros, then the subprogram call is G65.
Regards pi_1
Post your program here. Then someone will certainly help!
It’s hard to give general tips. It’s a very big field!
Regards
Boern
<b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
