584,829 active members*
5,070 visitors online*
    Jul 2003
    21
    help with 5v power supply
    I am finishing the hook-ups for my 3-axis xylotex board, have the 12v - 6amp power supply hooked up, fan , fuse and switch all done. I need to get a 5v power supply, is this something I could get at Radio shack and is there a particular one I should be looking for ? thanks for any help you could provide ..Jim
    Apr 2003
    1079
    You can get a "power steal" cable from xylotex that will attatch straight to the inside of the PC. Or failing that, just take the side off the comp, and grab a spare molex connector. Red wire is +5v.
    I got the power steal cable included with mine. Is there a reason you don't want to use that?
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Diy Power Supply Choices
    By berin in forum DIY CNC Router Table Machines
    Last Post: 07-13-2005, 09:47 PM
  3. 5 Volt Power Supply Tripping
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 04:05 AM
  4. Is this power supply rating adequate?
    By jerryrigge in forum CNC Machine Related Electronics
    Last Post: 11-25-2004, 05:06 PM
  5. Choosing a Power Supply for Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2004, 04:36 AM
