585,949 active members*
3,989 visitors online*
    Dec 2007
    6
    Hello guys!
    I had mill a pocket that was pivoted in the a-axes at 60 degrees.
    I set the a-axis at 60 degrees, equated the centre point to zero at x y z, programmed 5 axial high-speed cycle.
    The program works, but covering in the w axis isn’t axially parallel.
    Can anybody help?
    Hello Rapido!
    You have to write RX60.RZ0.G21 in isograph.
    Then call the high-speed cycle and program.
    Then the boring has to be 60° pivoted in the simulation of isograph.
    (rotation values always as head stands C is Z, a is X)
