584,812 active members*
5,321 visitors online*
    Hello everybody
    Does anybody know what this error message mean?
    from Locfile:
    17978 14:42:07 DPS100 OVERRIDE FEED CHANGED FROM 0 % TO 122 %
    17979 14:42:15 DPS100 OVERRIDE FEED CHANGED FROM 122 % TO 164 %
    17980 14:58:26 EEX400 TIME FOR FUNCTION AUCPRGCHK RUN OUT: AUCOL-ANTSWER NECCESSARY (MD*PRG=0) <--------------------------HERE
    17981 14:58:26 WEX144 N18736 X-167.995 Y-193.849 A-6.741 C-0.213
    17982 15:00:16 IWS183 DO YOU WANT TO DISRUPT THE EXCECTION IG THE CURRENT ISO FILE?
    17983 15:00:17 IEX452 EXCECUTION TIME DATEI 00:18:14
    17984 15:00:17 IUI053 COMMADN ACCEPTED: ABORT ACCEPTED
    17985 15:00:18 IPS021 PRESSED THE SPINDLE STOP KEY
    17986 15:00:18 IPS043 DESELECTED THE M03 MODE
    17987 15:00:18 IAU038 PLC FEED HOLD
    17988 15:00:19 IAU039 PLC FEED RELEASE
    Thank you very much in advance!
    Matthi
    You can mark the row and press F1 to see a command about the error message. It often doesn’t help though.
