584,860 active members*
4,928 visitors online*
    Dec 2008
    169
    Hello everybody
    I work at an old Hurco Bmc 40 with Ultimax 2 or 3.
    My machine moves about 11000mm in rapid motion. During program run only feed motion of 5080mm is possible.
    Can I fool the machine somehow, so that it would move faster as 5080mm?
    Then I would be able to make the orrect cutting values.
    Thanks in advance
    Stephan
    Paranuit Guest
    Hello
    The maximal feed motion is stored in the machine parameters.
    A telephone call to the service is a solution for sure. They can tell you where the parameter is.
    Yeah, that’s right. It stands in the service settings. But probably the feed is not groundlessly limited.
    Maybe it can lead to contour damages.
    Otherwise just take a look yourself. But don’t displace anything wrong!
    <b><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->&#33;&#33; Mein alter Nickname: canon &#33;&#33;<!--sizec--></span><!--/sizec--></b><br /><br />Beginnt man das System zu hinterfragen, so erkennt man deutlich, dass die „Wahrheit“ zumeist entgegengesetzt des scheinbaren zu finden ist.<br /><ul><li>Wenn wir uns heute keine Zeit für unsere Gesundheit nehmen, werden wir uns später viel Zeit für unsere Krankheiten nehmen müssen.</li><li>Wenn es klemmt - wende Gewalt an. Wenn es kaputt geht, hätte es sowieso erneuert werden müssen.</li></ul>
    Dec 2008
    169
    Thanks for your replies. I’ll ask the Hurco technician when he comes again.
    It’s wonderful to see how my Hurco roughs workpieces with a feed motion of 7000mm.
    Have a nice weekend
    Stephan
