585,760 active members*
4,037 visitors online*
    Nov 2007
    368
    Hi
    I have a problem with the feeds.
    Here an example: When I move with 4000mm feed rate around a corner, then the machine always brakes.
    I am working with CAM... so in Basic NC Ultimax 4..
    Can I switch that off somehow?
    So that it dashes around the corner without braking?
    Slowly but surely, it really starts to annoy me now....
    Many thanks in advance
    Hello
    The CAM program is not the problem- it’s the settings (parameter) of the machine.
    The reduction of the feed is desired in order to keep the cutting speed constant when going around the corner.
    You can switch off the controller in the parameter settings- have a look at the manual
    Regards
    Milling cutter
