585,932 active members*
3,684 visitors online*
    Aug 2012
    6
    Hello
    Sorry for the translation, but not much English, use the google translator
    My problem is this, I have a BMC4020HT which when turned on says:
    Non-System disk or disk error
    Replace and press any key when to ready
    if it detects the hard disk, hard disk screen says (s) Primary Master Cyl 1223, 16 head, 63 Sector, Size 602MB
    has 2 partitions C:EXECUTIVE_1 and D : PART_PRGS, has many files, but without any program
    I have many diskkettes, but not if I missing, or how to install, could help me with this
    the diskketes I have are:
    Ultimax CNC (Executive) Machine configuration disk 1 of 1
    LC Ultimax Disk Upgrade Patch Rev A EXECUTIVE_1 (007-4123-010) disk 1 of 1
    Ultimax Ultimax ultility Diskkette V1.05 (427-0004-023) disk 1 of 1
    COMPOSITE FIELD Ultimax Machine Configuration Version 1.10 (427-0004-025) disk 1 of 2
    COMPOSITE FIELD Ultimax Machine Configuration Version 1.10 (427-0004-025) disk 2 of 2
    Ultimax Ultimax CNC version 2.15 (Maint. Executive) (007-4123-013) disk 1 of 3
    Ultimax Ultimax CNC version 2.15 (Maint. Executive) (007-4123-013) disk 2 of 3
    Ultimax Ultimax CNC version 2.15 (Maint. Executive) (007-4123-013) disk 3 of 3
    Utlility Optikey Diskkette Software Option (007-4124-003) Rev B Ultipockets
    Utlility Optikey Diskkette Software Option (007-4124-012) Rev F Ultinet
    Utlility Optikey Diskkette Software Option (007-4124-001) Pkg Rev B 3D Mold
    Utlility Optikey Diskkette Software Option (007-4124-007) Rev B
    DXF
    Utlility Optikey Diskkette Software Option (007-4124-008) Rigid Tap Rev B
    Utlility Optikey Diskkette Software Option (007-4124-027) Rev H
    UltiPro (std)
    Security Diskkette Utlility Optikey Modifier (007-4136-005) Rev G SKCOX200
    Max 32 DA DA Max32 Version 1.61 Software Package Machine configuration disk 1 of 1
    Max 32 DA DA Max32 Version 1.61 Software Package (007-4123-002) ENG disk 1 of 3
    Max 32 DA DA Max32 Version 1.61 Software Package (007-4123-002) ENG disk 2 of 3
    Max 32 DA DA Max32 Version 1.61 Software Package (007-4123-002) ENG disk 3 of 3
    Thanks in advance, they are grateful for the assistance or the time to read this, sorry again for my English
    Regards
    Dec 2001
    5151
    Hello vimaro,
    welcome at the cnc-arena
    It seems as if the boot sector of your hard disk is damaged or is not correctly initialized.
    You should contact the HURCO support and possibly save even more important and useful data.
    sorry but more I can not write on the basis of this informations - it would be great if you write down here if you found a solution ... maybe with a little help by HURCO service ...
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
